loose sensor?
loose sensor?
So I know I have a vacum leak somewhere and I coming from the back of the intake mainfold. Is that sensor on the back of the manifold supposto have a a little play in it or has it been nocked looks. Becasue it moves around just a little when i move the brake vacum hoses.
It does have some play in it. It's clipped into the port by a plastic clip and it has an orange rubber seal that seals it. I had my intake off this weekend putting heads on and I took that sensor out of the intake to look at it. I noticed it's not a real tight connection. There is also a vacuum port right under that sensor. Check that connection and follow the hose down to the tee where it splits off, that could be a problem too.
