6, 5, 4th gear??? Tranny questions
Old 07-07-2005, 01:41 AM
Michael Ozorowsky's Avatar
Default 6, 5, 4th gear??? Tranny questions
Hey, is this normal? When I'm downshifting, going 6th, 5th, 4th gear, it grinds. Wants me to go into 3rd then I can upshift to 4th. Is this normal?
Also thinking bout having tranny "Freshened up" and maybe put a steel 3-4 shift fork in there at same time. How much should this cost me?
Old 07-07-2005, 08:13 AM
1madss's Avatar
Most likely 3/4 synchro keys. Could also be the synchro slider, 4th gear blocker ring, worn shift fork pads.
Rebuild usually runs 250 labor if you pull the tranny.
Parts:
4th gear ~150
steel shift fork $50
blocker ring, keys, shift fork pads come in a basic kit for ~150. This also includes the parts for 1/2 also.
Synchro assembleys run around 150 each.
Old 07-07-2005, 04:38 PM
GETSOMZ28's Avatar
Sorry to hear about the tranny. This is why I went with a rebuilt one.
If you have ring pliers, press, bearing seperator, and some short/long pullers (~18" or so) you should be able to do it yourself with regular hand tools. Me and a buddy rebuilt his with the blocker ring kit and steel shift fork. Doesnt take very long to rebuild one (~3-4 hours).
Old 07-07-2005, 08:28 PM
gator's 99TA's Avatar
no oz
