Car will not run after pump/injector install
Old 07-09-2005, 07:09 PM
meanls1's Avatar
Default Car will not run after pump/injector install
I just finished a racetronix pump install and a svo 30# injector install. Now, if you touch the throttle it dies. Runs super rough too. I've tried tuning for the injectors and it doesn't work. What do I do?
Old 07-09-2005, 09:36 PM
Dustin's Avatar
Are you sure the tune is good. I just put 42lbers in today and I could barely keep it alive, after a good tune it runs great.
Old 07-09-2005, 10:15 PM
meanls1's Avatar
Tune is good. I just checked the pressure. It has 0 after the car starts.
Old 07-10-2005, 01:16 AM
Ferocity02's Avatar
Most likely the pump. Contact Racetronix and see what they have to say. If the FP is 0, the car shouldnt run at all, you said it ran rough?
