EGR/AIR (limp home mode?)
Old 07-11-2005, 12:27 AM
StangKillaLS1's Avatar
Default EGR/AIR (limp home mode?)
I took the EGR/AIR and took cats off and put 02 sims on, My Service engine lights come on and I ran a 14.3 at the track and I know my cars a low 13/high 12 sec car. Someone told me my cars in a Limp Home Mode and the computer is pulling timing and all kinda of stuff and pretty much making my car slow as ****.
Is there any truth to this??
Old 07-11-2005, 11:11 AM
WS6FirebirdTA00's Avatar
it shouldnt unless you took the front o2 sensors out too, those are theonly needed things and the others are emissions, i wouldnt think it woudl go in a limp mode because of that
Old 07-11-2005, 11:33 AM
HumpinSS's Avatar
did you plug all your egr/air lines after removing the stuff. You may have a vaccum leak of some sort. can you pull the codes from the PCM
Old 07-11-2005, 11:41 AM
P Mack's Avatar
You put the o2 sims only in place of the back o2 sensors right? Yeah, you should definately find out what codes it's throwing.
Old 07-11-2005, 01:36 PM
Yeah I put the 02 sims on the back and kept the 02s up front. I bought off road headers with no EGR and blocked off the intake. Ill go back through and make sure nothing was left out. A friend of mines got LS1Edit, so Ill try and play with that for a little bit.
When we took all the 02's off there where 2 long and 2 short 1's, We put a long and a short up front, would that have anything to do with it??
