Purge 12v question
Purge 12v question
I'm wiring my purge to a 12v source as directed but I want to hook two leds to the purge and im going to have to splice into that 12v line so they turn on when the purge is active will these 2 leds pull to much current from the purge causeing it not to fully open
The LED's may drop the voltage by .7 volts or so but really use next to no current. Just make sure you use ones with built in resistors and wire them correctly. Otherwise you will smoke them. The purge will still work fine with those connected especially if the car is running.
