Which rockers do I need?
Moderator
I just ordered a cam from Cam Motion to go with my Crane dual springs setup. I don't want to start dropping needle bearings. Which arm is considered the best for what I'm looking to do?
Cam specs are 246/257 .632/.646 113+3
Rev limit will probably be around 7400, but may vary depending on where the cam makes peak power.
Suggestions?
Suggestions?
Moderator
Originally Posted by jrp
i'd look at the retro fitted stock rockers from nasty nate. i believe jason used stock rockers with his motor spinning to 7500 rpms.
or you can go all out and run some Jesel Mowaks.
