Rear Turn Signal not working
Left Turn Signal not working
My left turn signal does not work. When i turn it on the rear bulb just stays on and the front bulb does not come on at all. Any idea as to what the problem could be?
Thanks
John
Thanks
John
Front bulb on that side is probably dead, or the socket could be corroded. I had the same problem with both my blinkers. I replaced both front bulbs and sprayed the sockets out with contact cleaner, let them dry, and they both work normally again.
