series 2 vs series 3
Old 07-20-2005, 03:31 PM
jpscamaro's Avatar
Default series 2 vs series 3
do you have to, not should you, but do you have to have a series 3 carrier to use stock, gm, 3.42 gears? i need to know before i try putting gm 3.42s in my 2.73 stock rear end.
Old 07-20-2005, 04:02 PM
98_LS1's Avatar
if you put gm 3.42 gears in your series 2 carrier, you need to use a ring gear spacer
Old 07-20-2005, 11:17 PM
jpscamaro's Avatar
i need to use a ring gear spacer in order to have it work at all? or just in order to keep them quiet? or what?
Old 07-21-2005, 12:38 PM
98_LS1's Avatar
You need the spacer to get it to work.
Old 08-16-2005, 05:58 PM
TA4U2NV's Avatar
don't even bother, just get the right gears, if they make what's called "thick" 3.42's I dont know if they do, but I know i made the same mistake with mine and got standard 3.73's when I need to the thick 3.73's to make it work in my 2.73 rear end.
