Need help making my car driveable (just put big cam in!)
ok i got efi live..i just put a 233/239 in my car and it hauls ***! problem is it wont idle worth a **** and any time im backing up and stop it dies, and any time im going down the road and some to a stop sign or light it frickin dies..so what changes can i make to make this car more enjoyable..also it bucks and surges at low rpms..is there any way to fix this or do i just have to live with it? thanks!
ive got a write up but i cannot host it, i can email it to you once i get a chance, but pretty much you have to get the idle airflow all in line, the desired and actual idle airflow have to match at idle and your idle trims should be about 0, the closer you get to that the better the car will run
I've got a bigger cam that that and my car bucked and surged under 2k rpm until my VE was in line. Now I can cruise at 1500 no problem. You just need to go through all the steps for tuning a cam swap.
Originally Posted by WS6FirebirdTA00
ok ill try to get it to you tonight. i do have a shorter version, which is all you should need for your stuff, in another thread if you try to search for it. i would but my break at work is about over. i think if u search idle tuning 101 you will find it
