MAF problem
MAF problem
Ok, so i figured I'd try to squeeze a little hp outa the T/A. So i got SLP's smooth bellows and figured it would be a quick, easy install. The smooth bellows rubber is extremely hard and rigid which makes it really difficult to bend so that the MAF can clear the radiator. I wrestled with the damn thing for over an hour with no luck. I could not get the bottom of the rubber over the MAF. I even put the rubber in hot water which softened it up a little but it still would not go over the MAF. Any ideas or tips.
(click to enlarge)
Thanks
(click to enlarge)
Thanks
That is not an SLP smooth bellow, that is just a rubber reducer used in plumbing. Good luck trying to get that thing to fit. If you check out SLP's web sight I'm sure they'll have a picture of there bellow, which looks alot different then the piece you have.
