'05 escalade with turbo
The Trans-Go vacuum modulator with vacuum bypass. The "modified" Trans-Go Performance Shift kit, & if you are going in to the unit, then the Borg Warner Hi-Energy 3-4 8 clutch setup. This should be a start.
