whats the company that sells the cheaper bellows?
Old 07-27-2005, 01:32 PM
NOTFAST's Avatar
Default whats the company that sells the cheaper bellows?
not a fernco, but not the SLP either
i need something to replace my f*cked up stock one that barely fits between 85mm maf and TNT ring.
thanks for answering the n00bie question
Old 07-27-2005, 01:35 PM
Hawkn01's Avatar
Take a look here www.roadraceengineering.com/hoseandclamps.htm
Old 07-27-2005, 01:39 PM
NOTFAST's Avatar
that'll work....thanks
Old 07-27-2005, 02:32 PM
LETZ RUN's Avatar
NOTFAST.. you seem to have the same issue i had.. i had a PAIN IN THE *** trying to get the TNT ring, maf, lid and stock bellow on there.. i have a SLP smooth bellow that is just sitting there because I dont see how it would fit. if you do get something to replace the stock one, can you take a pic so i can check it out.
Old 07-27-2005, 02:34 PM
LawmanSS's Avatar
Originally Posted by Hawkn01
Sorry, but ...on the above linked page, check out the "Tuning Tip" under the listing for "Silicone Vacuum/Boost Source Hose"...it's classic!
Old 07-27-2005, 02:35 PM
LawmanSS's Avatar
Here...I'll save you the time of looking:
Tuning Tip: Red is a good color for all around performance, however with a big turbo blue gets upwards of 10 hp, unless you have stock cams, then only 5 hp. Purple is best for bottom end power, mix with red for excellent mid-range. For NT cars, shift all recommendations one hue towards a warmer color. Yellow hose should only be used on high compression NTs or turbo cars with welded differentials. Proper Sticker Tuning can be a successful work around for any of these concerns. ;-P
Old 07-27-2005, 04:39 PM
ninety9ta's Avatar
That's retarted!
