Trans oil pan torque sequence
I searched and searched but found nothing
I'm sure there's a correct sequence to tightening the bolts for the trans oil pan, anyone know what it is? I'm going to torque it to 8 ft/lbs (thats right about at the OEM spec for the 4l60e, that should be fine for my th350 right?). Reason being, the gasket is a cheap cork type, and it has a little leak. I bought a nicer piece that shouldn't leak...I hope. Thanks
