Door Lock and dome light/map light question
Old 08-10-2005, 02:15 AM
toofastSS's Avatar
Default Door Lock and dome light/map light question
My car was down for a while...now the door locks do not work..when I push the lock or unlock button the door, I hear a clicking noise under the passenger side dash. Anyone know what the problem could be?
Also....The dome light and the map lights on the rear view mirror are not working either...Fuses and bulbs are good..Anyone have any suggestions here?
Thanks in advance
Old 08-10-2005, 07:11 AM
Ungrounded Moderator
WhiteBird00's Avatar
All of those items are controlled by the BCM. It's possible you need to replace the BCM (although I can't imagine why lack of use would make it go bad).
Old 08-10-2005, 12:24 PM
OctaneZ28's Avatar
The BCM is located in the dash on the passenger side, so I would guess that you have a bad relay in the BCM. Figure out which one and replace it, and you should be good to go.
Old 08-10-2005, 01:32 PM
Sorry, the BCM is an integrated electronic box with no serviceable parts (at least according to GM). I've never opened one but the schematics don't show anything like a normal relay inside.
Old 08-10-2005, 10:04 PM
toofastSS's Avatar
I fixed it...it was the damn fuse...it had a hairline crack
Old 08-11-2005, 12:26 AM
OctaneZ28's Avatar
Yeah, you're right.
I dunno what the heck I was thinking of.
Getting my cars confused again...
