Stock Injector flow rate
Please let me know if this is correct. Stock injectors are 28.8 lb/hour. Stock fuel pressure is about 62 psi. Does anyone know what pressure the flow rate is measured at? I believe there is a standard (43,5 psi) but am not sure. Trying to figure out if the 28.8 is actual installed flow rate, and if not, what the flow rate actually is. Running the numbers, the injectors look too small for 400 HP and I don't see a lot of folks changing injectors with cam installations.
