LS6 short block with LS1 heads?
Old 08-11-2005, 12:33 PM
98F-1camaro's Avatar
Default LS6 short block with LS1 heads?
I currently have a set of stage 2 heads off of a 98 LS1. I am thinking about buying an LS6 short block. Will these heads work on this block? I did a search, but couldn't find anything.
thanks,
Ray
Old 08-11-2005, 12:38 PM
2001CamaroGuy's Avatar
yes........any LS1, LS2, LS6, and truck head will bolt on any LS1, LS2, LS6, and truck block......
if you ever want ported heads though, get rid of the 97/98 style perimeter bolt (valve cover) heads as they will not clear aftermarket rockers not to mention are harder to deal with.....
Old 08-11-2005, 12:46 PM
Thanks! I thought that was the case, but I wanted to be sure before I was stuck.
BTW, the heads I have are already ported. (see above post)
Old 08-11-2005, 02:03 PM
my bad....missed that part......
Old 08-15-2005, 06:03 PM
Mike Frey's Avatar
Unless the LS6 short block has the cam included, there is no difference between it and a 02-04 LS1 short block. Difference between it and earlier LS1 blocks is internal venting, so don't pay any extra for a no-cam LS6 block.
