Transmission bolt sizes
Old 08-21-2005, 04:55 AM
distortion_69's Avatar
Default Transmission bolt sizes
I need to know the sizes of the bolts needed to remove a transmission/convertor/flexplate from an engine. The engine is in a back of a truck so its easy to reach.
The bellhousing bolts are already finger tight, but the size would be nice just in case.. The flex plate needs to be removed also..
Just let me know so the buyer can bring all the necessary tools, as I have none.
Thanks,
Josh
Old 08-21-2005, 07:38 AM
cablebandit's Avatar
i do believe they are 15 mm. i'd take 10mm-17mm just in case.....the converter bolts...no idea...aren't they like allen head bolts? Never got to remove a stock converter/bolts
Old 08-21-2005, 12:29 PM
jxaxsxoxn's Avatar
TC bolts are either 15mm hex or 8mm allen head.
