th-400 experts in here
Old 08-24-2005, 11:49 AM
slow14U's Avatar
Default th-400 experts in here
I just installed a th-400, took out the M6 and I have a question. The torque converter is about a 1/4 in away from the flexplate. Is this normal? Should I just push the tq toward the flexplate to eliminate the gap, or is there a spacer I need to get. The nipple on the torque is already centered and in the flexplate, so there is no problem there. Any help would be appiciated.
Old 08-24-2005, 05:38 PM
jxaxsxoxn's Avatar
I'm not saying I'm an expert.
In my opinion a 3/16" gap is perfect, then pull it towards the flexplate and bolt it up.
As long as the front is in the crank pilot and the pump hub is not pushed all the way in you should be fine.
Old 08-24-2005, 08:00 PM
john kilgore's Avatar
Default gape
don't believe 3/8 for one minute, if the gap is 1/4 " add a one cut washer. 400 pumps are very tricky on that gap.
Old 08-24-2005, 08:51 PM
eric01ss's Avatar
hey pm NICk z28 he just did the same swap to his car like 2 months ago he might be able to help u
Old 08-27-2005, 04:11 PM
Hugh betcha's Avatar
Do a google search for rossler transmission. Their site has a detailed but simple procedure for adding spacers to set proper clearance. Make sure to check the converter to crank pilot hole engagement.
