Rods?
Rods?
HEY IM REBUILDING MY ENGINE. I ALREADY BOUGHT THE DIAMOND PISTON FLAT TOP W/-2CC VALVE RELIEF, 3.905 BORE/ 3.622 STROKE/ 6.098 RODS/ 1.340 COMP HEIGHT/ .945 X 2.5 WRIST PINS. I MAY HAVE A LITTLE EXTRA MONEY. U GUYS KNOW WHERE COULD I GET SOME FORGE RODS TO FIT THESE PISTONS. I SEE THAT IM GOING TO NEED 6.098 RODS, BUT THE ONLY ONES I SEE ARE THE 6.125 RODS. WILL THESE WORK? I HAVE A STOCK CRANK WITH P&P HEADS AND 266/266 585/585 112LSA CAM, AND STOCK ROCKERS. THANX FOR THE INFO
I Was Just Wondering Would I Be Better Off With The Stock Rods Which I Can Pick Up For $475 Brand New Or Should I Get The 6.1 Rod Which Are Around $600 Dollars. Im Building A Daily Driver Which I Would Spray 150-200 Once In A While. What Is Ur Oppinion?
