Prog Door Lock Uses for Extra Push?
What kinda cool stuff have you guys used on the extra channel produced from doing the progressive door lock mod? I did it a while back and i'm pondering what to use the extra button push for...
Ungrounded Moderator
Just be aware that whatever you connect for the "extra channel" will also be triggered if somebody presses the unlock switch on the passenger door. That's a side effect of the progressive door lock mod.
Of course there are ways around the probem (such as a relay to prevent activation when the ignition is on) but you should be aware of the possibility of accidental activation.
