How tight should the 8-rib belt be?
WOOHOO! Got Boost! - How tight should the 8-rib belt be?
I don't feel like I'm getting the boost I expected.
The setup is:
383
Holley 950 Pro w/FJO wideband
Edelbrock E-Tec 200 heads, ported
Solid roller, 230/236 at .050, 112lsa, .589/.602 gross lift
50lb. injectors
Longtube 1 3/4" headers
Big Bell intercooler
Mondo Bypass
7" crank pulley
3.12" blower pulley
I am seeing rubber dust around the blower and mount.
I have only seen boost at the motor of about 4psi.
The belt is pretty tight, and I have excellent pulley wrap. Do I need to make it tighter, or try something else? I am going to check the Mondo operation tonight.
Thanks,
Jim
The setup is:
383
50lb. injectors
Mondo Bypass
7" crank pulley
3.12" blower pulley
Thanks,
Jim
You need to tighten the blower belt much tighter than what you think is necessary, basically you want it almost tight enough that you could strum it like a guitar string. I've never had any problem related from having the belt this tight. You should never see blower dust on the housing. Bob
LS1Tech Co-Founder
If you can flex the belt, like you can your stock serpentine belt, you can get slippage, or worse, have belts walk off.
What blower do you have?
Based on your pulley combo, are you shooting for over 10psi?
I am running the Vortech V-2 S-trim. I just put a .5" shorter belt on it and cranked the tension up so the belt was much tighter than I've tried in the past.
WOOHOO! Got Boost! 7.5lbs of boost! THANKS! This is about what I expected after the intercooler. I could really feel the difference, and the datalog showed everything where it should be. No knock, AFR at 11.6, IAT at 124, timing at 22degrees. Hit the rev limiter for the first time.
I did have some 100 in the tank - I am hoping to be able to support 8lbs. intercooled on pump gas (91 here in NorCal).
I still need to play with the upper rpm fuel map. I see in the log where the duty cycle hit 98% very briefly. I hope that I can trim fuel to the point where it doesn't exceed 90%.
Does everything sound reasonable? This is my first FI tune and I'm trying to be very conservative.
Today's Picture:
Thanks again,
Jim
Today's Picture:
Thanks again,
Jim
LS1Tech Co-Founder
Nice setup! I guess you can see how the 3.12 works out, and then go to the 2.95.
Figure that the belt not only has to be tight, but it's stretching somewhat too. I'm running 2.85/8.00 pulley combo and have seen 18 to 21.5 psi, though my combo has not seen 21psi down the track.
Thanks, John.
I can't really go any faster because of the absolute redline of the V-2 (50,000).
This pulley setup hits the redline at 6200rpm.
Is it really bad to exceed the stated blower redline even by a few hundred rpm? My 2.95" pulley would put me to about 53,109rpm at 6200 motor speed. I am running a -8 drain line plus a -8 blower vent line w/K&N (as suggested by Vortech in their Racing User's Guide).
Thanks again,
Jim
Thanks again,
Jim
