Quick question reguarding WOT switches.
Old 09-10-2005, 05:53 PM
5.3litre's Avatar
Default Quick question reguarding WOT switches.
ok im in the middle of installing my tnt F-1 kit and i went to mount the micro switch that came with it and i cant find a good place to mount it..anyways i got to lookin at it and i dont like the idea of using it..so what are my options as far as getting another WOT switch and which ones are compatible with tnt?
Old 09-10-2005, 06:19 PM
brad8266's Avatar
Why not just use the one you have, mine is mounted right behind the butterfly of the throttle body. There is a bolt back there that I mounted mine to. If you dont want that kind of switch then get one of those modules that will know WOT by the voltage of the throlle position sensor. I cant remember the name of it right now. Anyway in my opinion, the micro switch works just fine.
Old 09-10-2005, 07:04 PM
5.3litre's Avatar
ok thanks can some more people tell me how they mounted their switches
Old 09-10-2005, 09:20 PM
Matt@HSW's Avatar
We have a bracket that mounts the WOT switch by the throttle body:
http://www.harrisspeedworks.com/shop...cat=322&page=1
We also have a TPS switch for $65.00. It will activate your nitrous system based off the voltage of your throttle position sensor. Our TPS does not use a screw for setting. It has a simple push button that is used for setting it up.
Matt
Old 09-12-2005, 10:51 AM
Nitro Dave's Nitrous Outlet's Avatar
We build a custom Billet unit.Its on sale right now for 29.99.Normally 34.99.
Here is the link to the instructions.
http://www.nitrousoutlet.com/outlet/...le_bracket.pdf
Dave
Old 09-12-2005, 01:01 PM
Robert56's Avatar
If you go down the threads a ways, you'll see this was covered in a couple threads. Pics and info in both.
Rober
