need help with timing tuner settings
Old 09-16-2005, 01:20 PM
BillS's Avatar
Default need help with timing tuner settings
I am setting up my system, (tnt 75 shot to start) with a timing tuner. I have read the instructions and I am a bit confused on the settings. I want the N2o to come in at 3k and go off at 6400, And I want a 4 degree retard when activated. Can someone list the setting needed for this for me?
Thanks
Old 09-16-2005, 04:11 PM
SDB
SDB's Avatar
I bet your ahving trouble setting the high point of the rpm window switch....
it is all in the instructions, just reread them and be aware of the 4 dip switches....to set the high rpm switch, you need to have the 4th dipswitch turned up, not down like the other 3 switches.
SDB
Old 09-16-2005, 04:59 PM
BillS's Avatar
Yea, I got the 4th dip switch up, now how do I set the RPM, which dial?
Old 09-18-2005, 08:11 PM
BillS's Avatar
can anyone else help me
Old 09-18-2005, 09:04 PM
Matt@HSW's Avatar
To turn off at 6400 RPM
Step 1: With the key off, turn the RPM (min) **** to 5.
Step 2: Then set the Spark Base **** to 8.
Step 3: Spark Base to 8
The Red LED will illuminate for 10 sec while the unit reconfigures.
The unit then reboots itself (Both LED's light for 1 sec)
Make sure the Mode 4 switch is set to on.
Step 4: Reset the switches as desired. Configuration is complete.
To turn on at 3k set:
RPM (min) **** = 5
To Retard 4 degrees set:
RTD **** = 4
Matt
Thanks
