How much converter run out is acceptable?
Old 09-16-2005, 04:24 PM
GTS346's Avatar
Default How much converter run out is acceptable?
I trial fitted my converter yesterday before engine goes in, all bolted up correct, put a dial indicator on the rear snout of the converter and spun the motor over.
I had up to 0.025" run out, this doesnt sound good too me, what is acceptable and what is too high as I do not wish to wear out my trans, input shaft, converter, crack a flexplate etc.
Old 09-16-2005, 06:08 PM
Yank's Avatar
That is Not how to check run out.
the converter must be set on a special fixture to ck. this.
what you are seeing is the flexplate it has + or - .015 at converter mounting holes to crank flange spec.
also you have the converter hanging off the engine bending the flexplate as the converter weight is not supported in the transmission front pump.
Old 09-17-2005, 05:14 AM
GTS346's Avatar
Yeah was informed today I couldnt get a correct reading off the flexplate due to flex, all sorted now anyway, thanks YANK !
