Texas Members - question about burning smell
View Full Version : question about burning smell
Charlie Hustle
09-17-2005, 10:00 PM
ive recently noticed a burning smell coming from the drivers side of the engine. if i let the car idle it doesnt smell at all, but once i drive around for a while then come to a stop, you can smell it pretty strong. i can also smell it coming from the drivers side ac vent. anyone have the same problem, or any suggestions? thanks in advance
Dustin
09-17-2005, 11:59 PM
Have you done any work on the engine to get grease or oil or any chemical on it, the engine will burn it off so that could be the burning smell. Also is anything touching your headers?
Chad02SS
09-19-2005, 01:20 AM
I had the a similiar problem but it wasn't limited to just the driver side. It ended up I ran over a plastic bag and it got stuck on the passenger side header. It melted to the header and no matter how hard I tried to get it off it still stunk for several months.
Good luck finding the problem. Does it smell electrical?
UTzo6
09-19-2005, 01:24 AM
I had the same problem when my turbo started leaking transmission fluid, but that will happen when you have an 80mm on a 2.0 : \
1gen
09-19-2005, 01:40 AM
did you get new painted headers? sometimes they burn off the paint for a while
98 Speed Trap
09-22-2005, 01:56 PM
I have had the same problem for the last month! Can't decide whether it was brake smell or coolant related. All fluid levels have consistantly stayed the same, although by brake fluid looks dark grey/black!
My brake booster seal just started leaking air as well.
RELATED???
