Trying to replace front speakers
Old 09-18-2005, 06:02 PM
ls1_cam2's Avatar
Default Trying to replace front speakers
but i cant seem to get to two of the bolts that are holding them in place. Trying to remove the door panel but cant get it off bc of the window crank(handle). HELP PLEASE!
Old 09-18-2005, 06:32 PM
GPz1100's Avatar
Use a thin flat blade screw driver to pry off the little door lock slide (the part that shows red when doors are unlocked).
You need to fit it behind the metal rod and pry. It should snap off..
Old 09-18-2005, 07:03 PM
Josh_101's Avatar
He's not talking about the door lock handle. Use a flat blade screwdriver to pry the little metal pin off the window crank.
Old 09-18-2005, 07:10 PM
GPz1100's Avatar
Josh, my bad.. You're right.
For some reason it registered that the door lock thingy was preventing the panel removal. Perhaps I got too much wind today (~200 mile bike ride).
