Loss of second gear
Old 09-19-2005, 12:31 PM
LoudFormula97's Avatar
Default Loss of second gear
I was driving hard through first gear and grabed second as soon as I let off the clutch I heard a boom and then no second gear. I can slide the shifter into second gear but nothing its like it is in neutral. no grinding, no noise or vibration just no second gear. anyone know what this is?
Old 09-19-2005, 05:56 PM
Bugsquawsher's Avatar
Yep
you sheared off all the synchro teeth on your second gear.
You need a rebuild.
Old 09-19-2005, 07:35 PM
thesource's Avatar
Thats correct !!! Time for a tear down .
Old 09-20-2005, 08:53 AM
midwestcookiemonster's Avatar
Build It!
Old 09-20-2005, 09:44 AM
ls1 joe's Avatar
It should be pulled apart and inspected so that you know what kind of damage you are talking about. Give me a call or PM about rebuilds. I am offering a discount for all LS1tech.com members thru the end of the month.
Thanks,
Joe
Old 09-21-2005, 06:50 PM
vortec_7's Avatar
I just bought a trans from a member on here with this same problem...I'm almost done with rebuilding it. It is more than likely the synchro teeth on your second gear.
