Timing chain strength?
Old 09-20-2005, 09:25 AM
Mike2kZ's Avatar
Default Timing chain strength?
How much stronger is a LS2 timing chain than a stock LS1 timing chain?
Old 09-20-2005, 09:48 AM
GuitsBoy's Avatar
Comparing the two, the ls2 is substantially thicker.
cyphur's Avatar
have you seen the comparo pictures???
they're quite a bit beefier. i haven't seen a tensile strength/stress test or anything, but its definitely quite a bit stronger than the ls1 chain.
Old 09-20-2005, 09:50 AM
robertbartsch's Avatar
ls1 chain stretches a bunch - i replaced mine with a double,,,
Old 09-20-2005, 10:58 AM
vettenuts's Avatar
I can't see how the chain would stretch as the material would need to yield. I think that GM intentionally put some slack in the stock chain to control bearing loads at the front bearing.
Old 09-20-2005, 11:04 AM
GuitsBoy's Avatar
Dont think of the chain stretching as the actual metal links being stretched individually, think of it more like each hinge in each link wearing in to one another . As this happens each link moves ever so slightly further apart. The idea is similar to offset grinding a stock crank for increased stroke. Add up the small seperation between each link and the sum results in a stretched chain. Even so, after 75K miles on my stock ls1 chain, I couldnt really tell a difference in tightness when I put on the new ls2 chain. There was still some slack in it.
Old 09-20-2005, 07:01 PM
KJ
KJ's Avatar
The LS2 chain is alot stronger than an LS1/Ls6 chain. In fact if you were to bring a stock LS1/LS6 car into your GM dealer for service work & it needed a new chain they would use the LS2 chain. We have built several 402 LS2 that are making big hp #'s, and that is the only chain we can use (for now).
We keep them in stock, if anyone is in need of one!!
Quick Reply: Timing chain strength?
