Patriot Stage III LS6 flow #'s
Old 09-20-2005, 02:10 PM
Z'mnypit's Avatar
Default Patriot Stage III LS6 flow #'s
Just got the flow #'s back from patriot. Specs are stage III LS6 heads with 2.08 intake & 1.60 exhaust valves. 62cc combustion chambers. These heads will be going on my FFHP 408ci.
.100 69.8 / 61.5
.200 142.2 / 116.9
.300 206.0 / 162.3
.400 254.5 / 207.5
.500 290.3 / 225.3
.550 305.7 / 230.8
.600 312.4 / 234.2
Superflow 1020
Clay Radius
4.030" Bore
Old 09-20-2005, 02:41 PM
Bryan @ Speed Inc.'s Avatar
damnit... i only got 307/230 @ .600 lift on my PP ls-6 stg 3's. i have a 4" bore.
Old 09-20-2005, 03:24 PM
Z'mnypit's Avatar
I wouldnt sweat it, its on 4cfm. Thats still good #s.
Old 09-20-2005, 03:34 PM
SporkLover's Avatar
Zimnypit.... if you dont mind me asking.... how much did it set you back after it was all said and done?
I am looking at heads right now... and those numbers look pretty close to the Dart 225 heads. If they perform the same... then it just comes down to price...
Old 09-20-2005, 03:53 PM
Gunnar@Patriot's Avatar
Heads like Z's are $1,195.00 per pair assembled.
Old 09-20-2005, 07:44 PM
Mr. Luos's Avatar
Good looking heads as well.
Mine are 314.0 and 228.8 at .600"
Gunnar, ever flowed any of these heads to .650"?
Old 09-20-2005, 08:31 PM
Z'mnypit's Avatar
I asked the same thing earlier. I dont think he does, well at least mine he didnt. Have you got to use you heads yet?
Old 09-20-2005, 08:36 PM
Mr. Luos's Avatar
No. I just picked them up from Byunspeed over last weekend.
Waiting on a couple more things to finish the build.
Old 09-20-2005, 08:39 PM
fotoboy's Avatar
I bought stage 2 and they did exactly what gunner said they would! very happy!
Special note: No exaust pipe flow numbers read low
Attached Thumbnails Patriot Stage III LS6 flow #'s-pp-ind-flow.jpg   Patriot Stage III LS6 flow #'s-pp-own-flow.jpg
Old 09-21-2005, 07:15 AM
Z'mnypit's Avatar
I had the stage II heads a couple of weeks ago. There were also badass.
Old 09-21-2005, 09:41 AM
On our flow sheets we go to .600". We do flow heads higher for our testing purposes and at customer request.
Old 09-21-2005, 12:19 PM
BIRDONNOS's Avatar
.100 69.8 / 61.5
.200 142.2 / 116.9
.300 206.0 / 162.3
.400 254.5 / 207.5
.500 290.3 / 225.3
.550 305.7 / 230.8
.600 312.4 / 234.2
Superflow 1020
Clay Radius
4.030" Bore
gunnar what springs do these heads come with, also my car is a 98 with perimeter sytle valve covers, i have a forged bottom end with 6.125 h-beam rods and diamond -2cc pistons, i would like a new set of heads and started leaning at the darts, but i am gonna run thunders t-rex cam and don't think there springs will match good with my combo. plus i only drive the car on the weekend so i would like to run max compression on 93 pump gas.
Old 09-21-2005, 12:32 PM
FormulaFire's Avatar
How do they compare to the AFR 205s?
Old 09-21-2005, 12:42 PM
Z'mnypit's Avatar
They have the Patriot Gold Dual springs. Rated up to .650 if im not mistaken.
Old 09-21-2005, 01:58 PM
These come with our Patriot Gold .650" dual springs, ti retainers, and Super 7 locks. Give us a call and we will go over the set up and get you fixed up.
Old 09-21-2005, 08:39 PM
soslo's Avatar
I like my PP heads
Quick Reply: Patriot Stage III LS6 flow #'s
