Throttle position sensor question...
Old 09-23-2005, 07:31 PM
frcefed98's Avatar
Default Throttle position sensor question...
Gettin some KR on my 98....yeah I know damn 98's.
I've noticed on my HPT scanner that my throttle position jumps from 0-1 while at idle.....why is it doing that?
My foot is completely off the gas peddle but it keeps on bouncing from 0-1 on the scanner???
Could this be causing some of my KR issues? If not, how would I get it to start reading correctly...or is this normal
J
Old 09-24-2005, 07:24 AM
frcefed98's Avatar
ttttttt
Old 09-24-2005, 09:39 AM
tici's Avatar
is it 1% or 1 Volt?
Mine goes from 0 to 0.4%.
Check if it's mechanically OK, also if there is moisture in the sensor: mine had water inside and was showing higher values than 0%, also at WOT it was less than 100%.
I have a WI system and I think water was coming from it because it smelled like alcohol in the TPS.
This was messing the AFR at WOT and the shift points + pressure also.
KR coud be related to the TPS, but being a 98 it can be the KR sensors also.
Old 09-24-2005, 10:12 AM
bmfcamaro's Avatar
maybe the throtle screw is right at that median between 0 and 1 %. try adjusting a little.
Old 09-24-2005, 01:20 PM
frcefed98's Avatar
Its percent, sorry about that I'll take it off and clean it out maybe its gunked up somehow.
Thanks,
J
