A4 to M6 swap. Need to know witch codes to edit.
OK i have read some much my brain hurts. I did the A4 to M6 swap and everything is running perfect. Does any one know how i can get my TCS to come back on line so i dont have the damn light on the dash any more. Or will it just go away when i get delete the tranny codes.
I made a lot of researches about programming after a swap. Result: sure you can delete all the codes and the car will drive, but it won't be the same as with a M6 program. I think there are some safaty issues involved also (TCS +Airbag).
Carputing helped me with a LS1Edit program that fits my PCM (98), with a 99 it should be easier.
By the way: how difficult was it getting the parts for the swap? I have the M6 program ready but I still miss the parts! (weird, isn't it?)
How have you cut the shifter hole? Grinder? Dremel? Saw?
Have you bought the parts separately or was it a swap kit from a company?
OK I know it was about programming but I want to have a plan before I start taking my car apart for the swap.
Which editing software are you using?
