T-rex
Old 09-28-2005, 07:05 AM
venom ws7's Avatar
Question T-rex
hi everyone we just received our Thunder Racing T-REX cam
(not my car) the car is 99 z28 full bolt ons
4.10
ls6 ported oil pump.
lifters.
now about the install thunder racing website writen that piston to valve clearance must be verified when using modified cylinder heads.
and we are running stock heads.
so what do i have 2 do?
BTW the cam is 243.249/613.622 109 LSA
oh what do think will it dyno with a good tune?
thanx in advance.
Old 09-28-2005, 08:14 AM
777's Avatar
I'm sure you know this, but to swap lifters you have to take the cylinder heads off. The T-rex can just be installed with stock heads. The reason they say that is because it is close on the piston to valve clearance and when you have heads that have been milled the pistons will contact the valves during operation if you have milled very much off. Just install the cam and you will be fine. It should make around 415rwhp.
Old 09-28-2005, 08:23 AM
PREDATOR-Z's Avatar
To install a cam that big (or any cam for that matter) without degreeing it is either stupid or madness.
Not all motors have the same piston to deck measurement.
Old 09-28-2005, 08:45 AM
venom ws7's Avatar
thank you guys 4 the help.
and yes i knew i have to take the cylinder heads off.
