NOS System from an LT1 to an LS1?
I was wondering if an NOS LT1 kit will work on an LS1. If it needs to be modified what modifications need to be made to make it work on an LS1?
TIA.
Ray
TIA.
Ray
LS1TECH Sponsor
If you are going to continue to use it as a dry kit you just don't use the bypass regulator. The blue regulator between the two solenoids would just need to be taken out and the hole plugged. Then just put the nozzle to the air box.
