Low Fuel Pressure and Shark Nozzles
I am going to run a dedicated low pressure pump (8 psi) for my nitrous set up.
I know the Shark nozzles were designed with EFI fuel pressure in mind.
(40+ PSI)
Will there be any atomization/flow issues if I run them at a lower PSI?
I know I will have to adjust my fuel noids to a bigger size (I assume I can use carb pill sizes as a base)
I plan on runing a homemade set up based on 2 shark nozzles (I ran into a extra NX kit for cheap) and 100 to 150 shot each.
Location will be rigth after the MAF.
(40+ PSI)
