is this right? or is the car falsely taking out too much fuel?
Old 09-30-2005, 03:58 PM
WS6FirebirdTA00's Avatar
Default is this right? or is the car falsely taking out too much fuel?
in the upper left hand side of the fuel trim histograms eveyr time i go out the trims dip way way down negative. my ve table is also getting pretty damn low in these areas. it always happens on decel/letting out of the throttle. dfco is shut off. im just afraid that this is false data from the injectors railing positive. i dont want to have a lean condition when giving the car throttle and being in those cells
Old 09-30-2005, 04:50 PM
LS1 Tech Administrator
Patrick G's Avatar
You won't be in those cells at anything other than decel. Once you give it any kind of throttle, you'll switch over to the cells to the right. I woudn't lose any sleep over it. Besides, at least they aren't positive. Positive might sway your l-trims the wrong direction.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 09-30-2005, 04:58 PM
ok thanks, i was just worrying that on decel the engine might be running lean, and if i pick the throttle up slightly in those areas that it stays there, dont want problems
Old 09-30-2005, 06:05 PM
Patrick G's Avatar
If the trims are showing a negative number, then your motor is rich and the pcm is having to pull fuel to achieve stoichiometric 14.63 A/F ratio. Not a bad thing to be rich at high vacuum signals IMO.
Old 09-30-2005, 06:17 PM
yeah i know that, i was just worrying about the VE table going so damn low. plus i know with my injectors i had before i was having issues like that at idle, it kept making me pull fule and pull fuel, well the prop fueling was off and gave a faulty rich condition so what i was taking out shouldnt have been taken out
Old 10-01-2005, 12:26 AM
Patrick G's Avatar
Makes total sense. That's why at a certain point, I just look at the shape of the VE curve. If it doesn't look like the torque run of a dyno graph, it's probably off. Hand smoothing can keep you in the ballpark.
Old 10-01-2005, 01:47 PM
if it keeps giving -11 im gonna add fuel and see what it does
