Can I reuse fuel injector o-rings?
Old 10-02-2005, 01:58 PM
~JOSHUA's Avatar
Default Can I reuse fuel injector o-rings?
Did a search and didn't find . After 10 minutes I gave up.
I'm putting the manifold back on the car and I read somewhere that you need to use new o-rings if you take the injectors out. I went to the dealer and they only have them seperately if it's a 3.4 liter. If it's the 5.7 you have to buy the whole injector. The o-rings look in good shape, I'm putting them into an aluminum (Weiand) intake. Any problems? Thanks.
Old 10-02-2005, 02:15 PM
oange ss's Avatar
LS1Tech 10 Year
re-use them, just be sure to inspect for nicks or cuts and use Vaseline or grease before installing them
Old 10-02-2005, 02:20 PM
silverTA2002's Avatar
I reused mine during heads/cam swap this week.
Everything is fine. Just be careful, and inspect them like he said.
Old 10-03-2005, 08:16 AM
~JOSHUA's Avatar
Thanks all! I appreciate the help.
Old 10-03-2005, 01:08 PM
strokedls1's Avatar
If you have a bad one you can buy a set of orings for a 90 ford mustang from kragen or autozone for like 8 dollars. It is the same size as the ls1 injectors use.
Old 10-03-2005, 02:21 PM
~JOSHUA's Avatar
That might come in handy someday. Thanks.
Quick Reply: Can I reuse fuel injector o-rings?
