H/C install, no tune, runs great
Old 10-04-2005, 01:51 AM
00Z28SS's Avatar
Default H/C install, no tune, runs great
I just installed, all at once, patriot heads, 224 581" cam, LT's and TSP duals. I started it up and crazily enough, it ran and idled just fine! After working all of the air bubbles out of the cooling system I took it for a ride and it runs AWESOME. I have HPTuners on the way and I thought I would need to tune for sure for it to even run at all. I just wanted some feedback from everyone as to how their car ran after a similar install.
Old 10-04-2005, 02:00 AM
tbojbob's Avatar
Fantastic! You need to go buy a lottery while you're at it........
That's a classic streetable combination!
Old 10-04-2005, 04:49 PM
cowboysfan's Avatar
good to hear all went well. I am about to do same. w/ patriot heads,tsp cam, oil pump, kooks lt,y-pipe,eng mounts. did you install lt from top w/ heads off? if so how easy did they go in? I'm getting ready to order all this soon. thanks for the help. good luck. keep us up to date.
thanks
fuerzaws6
Old 10-04-2005, 05:25 PM
silverTA2002's Avatar
Car idled and drove ok.
When I'd give it 50% or more gas, I'd get some knock. But, this wasn't a stock tune, it was max timing w/o knock before heads/cam.
Tuned, no problem.
Old 10-04-2005, 06:51 PM
M6HuggerSS's Avatar
my car ran great after H/C/I...
the pcm is great at adjusting it self to changes made.
but the car felt even better after a tune.
drive the car for a coulpe weeks, then go get it tuned and you feal the diff.
good luck!
Old 10-04-2005, 06:59 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
good luck!
Couldnt have said it better myself....for my first cam that is. The 244/248 fell flat on its face.
Old 10-04-2005, 11:47 PM
00Z28SS's Avatar
I did the whole install from the top of the engine. It's not nearly as bad as it looks once you start removing engine parts. I would follow the guide from ls1howto.com. It was a great guide to reference from. I was even able to keep the A/C system sealed.
