LivernoisMotorsports
10-04-2005, 01:19 PM
(2) TiAL WG40mm Wastegates
This wastegate retails for $380.00
New, never used $280 each + Freight. Will seperate.
- High temp NiCrFe based alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs
- High temperature silicone Nomex reinforced actuator diaphragm
- 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C)
- Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing.
- All Stainless Steel hardware
- Mating weld flanges are 304L
- Anodized aluminum actuator
- Includes air fittings and stainless hardware
http://www.detroitspeedworks.com/gate.JPG
Thank you,
Rick
Thank you,
Rick
