A million window switch ??s!!!!!
Yes I have searched and I seem to be getting more confused as I go....
The Window switch supplies GROUND at a certaiN RPM, correct? Some pics I have seen show the yellow wire of the MSD going to the microswitch...but there is no ground on the microswitch so I am confused.
I thought to do it this way... + out of the main arming switch to the micro switch and the the microswitch goes into the switched side of the relay. Ground from the relay comes from the output ground of the window switch.
Can anyone clear this up?
Also, where do I connect for the tach wire...#10 white, but that does me no good without a pic!!
Thanks for any help.
1 Post
The microswitch can be wired on the +12v side or the grond side. I always wire mine on the +12v side so it the switch grounds some how it pops a fuse and not activate the system
Closed ex-Sponsor Account
Just leave out the FPSS if you do not have.
Ricky
