New to Nitrous
Old 10-06-2005, 12:51 AM
zspot98's Avatar
Default New to Nitrous
Listed below are the mods I have waiting to be put on my 98 z, but my questions is. Is there anything else I will need to do/worry about if running a NEX wet kit w/ a 150 shot. Thanks is advanced for the help!
Comp Cam=Lift Int/Exh-581/581 Dur Int/Exh-224/228 LSA-112
LS6 Intake
Ported TB
Jet Hot long tubes
Harland Sharp 1.7 rockers
Comp 918 springs
3600 stall
LS6 oil pump
Double rolling timing chain
Old 10-06-2005, 06:22 AM
XTrooper's Avatar
Depending on how much power you end up making, you may want to consider upgrading your fuel pump.
Old 10-06-2005, 06:36 AM
Airwolf's Avatar
TR6 Spark plugs... Gapped .035"
Old 10-06-2005, 09:25 AM
Nitro Dave's Nitrous Outlet's Avatar
I second both the suggestions above.Fuel pump and spark plugs...
Dave
