Keyless Entry?
Keyless Entry?
I just bought a 1996 Firebird with power locks and everything but it does not have keyless entry or at least the guy did not give me the switch. How do I find out for sure if it has keyless entry and if it does not How do I uprade and put keyless entry on it?
Thanks,
Thanks,
Thanks,
Thanks,
...How do I find out for sure if it has keyless entry?...
1. Put your key in the ignition.
2. Turn the key to RUN.
3. Turn the key to OFF.
4. Remove the Radio Fuse.
5. Turn the key to ACC.
Count the number of chimes. If it chimes once, you do not. If it chimes twice, you do.
Here is an exerpt from my owner's manual.
If it is the same for your car, then it must have come with keyless entry. You can download your owner's manual here if you don't have one.
http://www.firebirdgallery.com/downloads.htm
You can order a new Keyless Entry Fobs & Batteries from http://www.gmpartsdirect.com for $36.87 (P/N 16245100) or try your luck on eBay. http://search.ebay.com/_Parts-Access...QQsofocusZmppf I got mine for $29.95 plus $4.95 shipping.
You can find out how to program it here: http://installuniversity.com/install...ar/key_fob.htm
Hope this helps!
1stbird
2001 Firebird Formula
Purchased 8/19/2005
LS1
6 Speed (M6)
Ram Air Hood (Dealer Installed)
Ram Air Box (Dealer Installed)
K&N Air Filter
CAGS Eliminator
DRL Disable
Black on Black
No T-Tops
GM Factory Bra
Pilot Motorsports Shiftknob
Pilot Motorsports Pedal Covers
"My old lady left me and took my Firebird the other day. Damn, I miss that car!"
Hope this helps!
1stbird
Purchased 8/19/2005
LS1
6 Speed (M6)
K&N Air Filter
CAGS Eliminator
DRL Disable
Black on Black
No T-Tops
GM Factory Bra
