wide band 02
if you have cats this could be a problem... there is only one way and you have to swith the wideband sensor to each side of the exhaust. two bungs installed. but each bank is going to be very close in terms of afr... unless your having a problem.
if your not running cats then right after were the y-pipe starts... if you have and x-pipe then right into the x. i have mine installed in my x-pipe and it's reading just fine.
