Putting LS2 402 in '98 f-body, do I have to open loop it now?
Old 10-10-2005, 03:44 PM
V-10 Killer's Avatar
Default Putting LS2 402 in '98 f-body, do I have to open loop it now?
I'm just wondering what I have to do to get this thing to run half way decent with my '98 PCM. I don't have as many cells in my MAF tables (stops at 11,250 hz), and with my 85mm MAF, I can't read past 360 g/sec. Am I stuck using the low resolution secondary VE tables to run this beast now, or is there another option I haven't seen yet? Can I force it to use the Primary VE tables somehow?
Thanks
Old 10-10-2005, 04:27 PM
SmokingWS6's Avatar
You can still run in closed loop mafless, known as speed density(SD) mode. It'll still use the o2 sensors as an a/f reference. Are you sure its maxing out your maf?
Old 10-10-2005, 04:33 PM
P Mack's Avatar
To use the primary ve on a 98 you'd have to get your operating system changed by hptuners (speed density enhanced).
Edit: nevermind, they only offer speed density enhanced on 99 & up.
Old 10-10-2005, 07:27 PM
Yeah, I maxed it a few times around 6850 rpms with my current stock displacement setup. The car is putting out 402rwhp and 468rwtq unlocked, and the A/F ratio is perfect so the numbers support me being maxed.
Yeah, these F'n '98 pcms are really starting to rub me the wrong way
Old 10-11-2005, 12:48 AM
SmokingWS6's Avatar
I tuned a 430rwhp car the other week that did not come close to maxing out. Just over 10,000 at peak.
I know, port the maf, lol... larger maf's will read a lower frequency at the same air flow due to its increased air flow capacity, which is why maf tables will need to be edited.
Old 10-11-2005, 07:30 AM
P Mack's Avatar
That is probably actually his best option. Also you could get a Pro M maf or something that is much larger but has the same frequency range.
Quick Reply: Putting LS2 402 in '98 f-body, do I have to open loop it now?
