does 2000 silverado have an LS1?
I am looking at buying an ls1 that is claimed it came out of a 2000 silverado, yet I never heard of any truck with an ls1 in it. Can anyone help me out?
Thanks
Thanks
Silverados came with the 4.8L and 5.3L which I believe both are Ls1 blocks. I am not totally 100% sure but a buddie of mine had a 4.8L in his truck and it was a ls1 block!
Thanks, I am just having a hard time verifying that it is an ls1. Here's the ad :http://www.craigslist.org/sby/pts/103328366.html
I mean, it sure looks like an ls1?
steel block ls1?
steel block ls1?
Originally Posted by 2K2WS6TA
If it's the truck engine some of the parts from the LS1 will bolt on (heads, intake) it's based on an LS1, but the heads, intake, and front accys are different
It's similar, but it does have some differences, it'll bolt in place of an LS1, so the mounts are the same, and the heads and intake will exchange, the front accys need some bolt holes drilled and tapped(LS1 to truck), if you go to the truck section they can tell you better than I can
