Elementary electronics nitrous wiring question
Old 10-12-2005, 12:43 PM
transsam's Avatar
Default Elementary electronics nitrous wiring question
I am wiring 2 solenoids and need some advice. Would it be better to run the 12v to the solenoids:
1. One from each of the "87" outlets on the relay.
2. Only use one 87 and splice a second wire into the primary to power each.
3. Run the solenoids in series ie. - run the power from the relay to the input on solenoid one. Run the out from solenoid one to the in on the solenoid two. Run the out on solenoid two to a ground.
Sorry for a silly question, but I can't figure out wich one would work best. Thanks for any input.
Old 10-12-2005, 01:02 PM
XTrooper's Avatar
I don't think it really matter how you do it as long as they both end up getting power.
Old 10-12-2005, 01:12 PM
BadAssFast's Avatar
Not a silly question - depends on how much current goes through the pair...that depends on what solenoids you are using...and which relay too...assuming the current draw is acceptable for the relay it shouldn't matter. It's a matter of balance of current. Sooo - name your manufacturer and a vendor will come to your rescue.
Old 10-12-2005, 01:22 PM
David@TNT's Avatar
http://texasnitroustechnology.com/instruction%20pdfs/Electrical%20Instructions.pdf
Old 10-12-2005, 01:27 PM
transsam's Avatar
NX Solenoids (not sure which ones, but they are BIG).
30 amp fuse.
12 gauge wires
Old 10-12-2005, 02:07 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
You could come out of a relay that has 2 87 pins one to each noid. I donot recommend it, it you do I would still strip the wire and create an X type connection..
Here is a drawing that has always worked for me.
Never run noids in series..
Ricky
Old 10-12-2005, 02:20 PM
transsam's Avatar
"never run noids in series" That is one of the big ones I was looking for. I will splice it like has been suggested by EVERYONE so far. Sounds like that is the best bet. Thanks for the quick replies and great help folks!
