how much should i mill to 11.0?
Super Hulk Smash
Generally .006-.008 shaved will give you 1cc off the combustion chamber (depending on the shape, size, etc.), so if you want 11:1, I need to know your current gasket and whether this is a stock 346, or stroker.
Assuming you are using the stock GM gasket .054, and piston out of the hole .008" on a stock shortblock, I get 10.71:1 CR as it stands (10.5 would take .005" out of the hole and .060" gasket). To get to 11.2:1 would take a 60cc chamber, or .024" shave. That'd give you 11.27:1 with the first set of conditions, or right at 11.0:1 if you are using the second.
So, mill it .024" and you'll be in your range. It will bump compression a good half a point.
Super Hulk Smash
Originally Posted by baloga41
making 441 rwhp and 410 tq now w/o milling what do y'll think i'll get after milling?
so gains of increasing the comp. by 0.5 will be around 10-12 hp and 20-30 tq???
does anybody have dyno of b4 and after milling only?
Personally, I didn't mill, but went with a thinner gasket, a .040 cometic. Higher compression without milling and better quench.
Originally Posted by silverTA2002
I doubt you'd gain that much from just milling, but if the added compression doesn't cost any extra $$ and won't hurt anything, why not?
let me know how this pans out i was wondering about bumping my compresion when I do my heads and cam over the winter my big question is if I am going to mill them should go to 10.8 or 11.0 let me know thaqnks jay, 98 t/a a4 bolt ons and free mods
Originally Posted by FiveSevenEagle
detonation will kill u , especially when u are in the middle east and u want to spray 150 shot !!
am i right guys ??
am i right guys ??
I spray up to 200 dry in Dubai. It is all in the tuning and we have 98 Octane gas. also I run 11:1 Compression with TR6 NGK gapped .035
hi predator ,
useful comments , so the others ,
BALOGA , he said 98 octane 98 OCTANE did it ring in ur head .. not 93 octane .. ok ok dont tell me that we will add torqo .. wagd ganna use the car everyday !
it is not that dangrous to go with this compression + or - juice , am saying what would be the difference .. 10 , 15 lbz of torque why not to be in the safe side and add some juice .. 250 for instance .. since he already has the F2 and the 255 pump ?
anyways either he is going to mill it or not i dont disagree with u ,
u r right
u r right
