Building Z28 into drag car, order of buildup question
After 11 years, I am finally ready to begin building my 94 Z28 into a drag car. I am financially able to do it after all this time and plan on doing the buildup completely myself (except for anything beyond my abilities....wiring and PCM). I have tackled building and installing everything in various F-body's except the fuel system, and feel I am ready to tackle my first buildup. I figure it will take about a year. Maybe 2 years depending on if my newborn is well behaved or not.
My question is where should I begin? I am putting in a low compression ls1-ls2 and a yet undertimined turbo/supercharger, a strong TH350/400 from a local shop, 9inch rear, etc. The order I plan on working right now in order is
1: Fuel system
2: Rear end/suspension/chassis
3: All LS1/2 conversion pieces
4: Build engine
5: INstall engine & tranny
6: PCM, Wiring
7: Get it running and tuned, body shop
It seems like a stupid question now that I list everything. It seems logical and I was always told work from the back of the car forward. A lot of work is already done. Full BMR/PA Racing suspension (minus 1 or 2 things) is in the car, LS1 brakes and front end are done and Roll cage is in. I figure building the motor/installing PCM harness will be the hardest part, then followed by fuel system because I have never done it. BMR LS1 K-frame is waiting for the motor already.
Or maybe I just need positive encouragement because I am about to tackle the largest project of my life (my child) and am building my first car at the same time, lol. If I can raise a kid the car should be cake. I am a firm believer that you only know if you can do something if you try, so if I build a monster or blow it up I am going to do it.
1: Fuel system
4: Build engine
6: PCM, Wiring
Originally Posted by Carbed4thGen
I would start with the rearend and suspension first that way you know EXACTLY where you cna route fuel lines, brake lines, and any excess wiring.
We are also working on which rear end to go with. The debate is what gearing would be right for the combo, we can only make a guess right now; and if i should get a narrower rear or not. The debate there being if I will run the car with ET Streets full time or if I will put 18/19's on it for the street. I will probably go 2" narrower per side for a nice dished look regardless. I am still swirling from all the things that must be done to do the car right, and trying to get everything to mesh as a combo is a pain in the ****. For all those people who have built a 9/10 second car, what did all the little extras cost you, the things you don't think of that pop up like bolts and sensors etc. I figure maybe 4K extra set aside may cover it.
7 Second Club
i wouldnt let the body shop touch it until a season of driving it.... with that much power coming from a T/C or S/C she is bound to scuff the wall if your not used to it... especially if its a totally new setup....
i understand you dont wanna hear that but..... it happens
Originally Posted by ty_ty13
i wouldnt let the body shop touch it until a season of driving it.... with that much power coming from a T/C or S/C she is bound to scuff the wall if your not used to it... :
