will this get me 450 rwhp?
Old 10-20-2005, 04:15 PM
Okie02's Avatar
Default will this get me 450 rwhp?
ok im wanting 450rwhp. you can see me current mods and numbers in my sig..right now i got 420...i bought some PPstage2 ls6 heads 59cc a while back for a different project, but i never finished it and sold it so now i have these heads just layin around and i figured i would bolt them on..i think i can get 30 more hp out of them..what do yall think? and also does anyone know if these heads will clear with my 233/239 cam?
Old 10-20-2005, 04:17 PM
ryan-63nova's Avatar
just try it, whats the worst that can happen..............
Old 10-20-2005, 05:05 PM
02 Camaro SS's Avatar
There should be a pretty good possibility
Old 10-20-2005, 05:24 PM
ninobrn99's Avatar
with that giving you a 11.xx compression and if the cam is on a 112 i would think more along the lines of 425-430, but with the 90/90 setup also, then yes. Thats with a good tune as well. If they're the older heads, spend the money now and have them looked over and make sure none of the parts are loose or too big/small for the heads..ie valve guides, seals just extra insurance.
Nino
Old 10-20-2005, 05:44 PM
SideStep's Avatar
I hit 450 (sae) without the FAST so I will say you can hit the number... it is going to depend on the tuning.
When are you doing this???
Old 10-20-2005, 05:47 PM
ninobrn99's Avatar
true, but your running afr's and he has patriot heads...from all the talk on the boards, there's a big difference between the two.
Old 10-20-2005, 07:30 PM
M6HuggerSS's Avatar
whats the lift on that cam.....? you may be cutting it close!
but if it all worked id guess around 430-440rwhp!
good luck.... dont forget to post up results!
