no SES light with MAF disconnected ?
in order to dial in the VE properly you need to make sure that the engine is running completely off the VE table without the MAF interfering.
once you have the VE dialed in then you can reconnect the MAF and adjust maf
Originally Posted by Ragtop 99
Why not leave it plugged in? Couldn't you can measure MAF airflow vs. Dynamic airflow and get a jump on dialing in the MAF while working on your VE table?
Fail frequency has always worked for me. If its not I suspect the code has been turned off in your pcm file.
LS1TECH Sponsor
Originally Posted by SmokingWS6
Yep
Originally Posted by foff667
Not saying you can't...I've heard of a few instances where for whatever reason the car didnt instantly drop into SD mode...the extra 12-15 seconds to get out of your car, pop your hood, unplug the maf and drop the hood isnt that much extra work to make sure its in SD as far as im concerned.
until your VE is dialed in perfect...then its not going to be accurate...
plain and simple... it used the VE to get its #'s for accuracy...
only way to correctly and accurately get the MAF is to use a wideband and use AFR error % to get it right
