Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
572 Big Block! ! !
Old 10-22-2005, 10:46 PM
Duffster's Avatar
Default 572 Big Block! ! !
how much fabrication in the front suspension would be necessary to squeeze this block with headers into the Camaro? Obviously beefier suspension would be required due to the weight, but wouldn't the a-arms have to be custom? Thanks
Duff
Old 10-23-2005, 07:45 AM
LS1TECH Sponsor
mikey's Avatar
Contact Madman & Company ------------->
Old 10-23-2005, 11:17 AM
slow trap's Avatar
i would think only slightly stiffer springs would be required.an aluminum headed big block is around 200 -250 lbs heavier.
Old 10-23-2005, 01:46 PM
Thunder175's Avatar
Coilovers with out a doubt. BMR makes a K-member already bossed for a SBC or BBC, so that is another thing you are going to have to install. Also you are looking at at least front and mid motor plates if the motor is making a large amounts of power. To many other things to consider to get into in a quick reply...
Who is building the motor?
Old 10-23-2005, 04:19 PM
LS1Tech Sponsor
MADMAN's Avatar
Give me a call. I have the motorplates and all the other items to install in stock. 281-290-8899
__________________
www.madmanandcoracing.com
225-343-9029
Old 11-01-2005, 01:54 PM
BIGBLOCKXJ's Avatar
Do you need to disable the Air because the head interfers, or does everybody disable the air because it uses to much horsepower.
Thanks for you help.
Mike
Old 11-01-2005, 02:14 PM
Thunder175's Avatar
Uhh, because there is no way physically possible to install a big block in a stock chassis'd 4th Gen F-body with the air conditioner in it... at least not that I can find.
Old 11-01-2005, 03:39 PM
BIGBLOCKXJ's Avatar
Sorry to be stupid, but what part of the air interfers with what part of the car? Is there an issue with the compressor? Is there an issue with the condensor? Is there an issue with the heater/air box at the firewall?
Thanks in advance for the information. Just trying to figure out if I should sell the 95, and change cars.
Mike
Old 11-01-2005, 07:35 PM
ronbros's Avatar
heater/air box in the way on mine. had to take them out , you could use a different A/C system. RON
Old 11-01-2005, 09:58 PM
BIGBLOCKXJ's Avatar
Do you think a unit from vintage air will work? Do you think you could have moved the heater/air box over some? Do you think it would clear with stock valve covers (or were you using stock low profile covers)
Again, thanks for the help.
Mike
Old 11-02-2005, 11:29 AM
Thunder175's Avatar
I don't see how it can be easily moved without modifying the firewall... Someone correct me if I'm wrong
Old 11-02-2005, 02:13 PM
BIGBLOCKXJ's Avatar
Thank you for all the help. The k-member and headers will be a great start (as I had to fab them for the Cherokee). By the way, the air works on the Cherokee, and the engine bay is smaller.
Mike
Old 11-02-2005, 03:38 PM
Outlaw's Avatar
thats a 572 test fitted in my car.. did not have headers on it at that point
Old 11-02-2005, 06:01 PM
BIGBLOCKXJ's Avatar
WOW, great picture. Perfect view. I think I know what needs to be done now.
Thanks,
Mike
Old 11-02-2005, 07:16 PM
Thunder175's Avatar
What headers did you end up using? Totally custom fabricated or something along the lines of the Hooker 2455's that someone mentioned in another thread?
I have plenty more questions for you as well...
Old 11-02-2005, 07:47 PM
Outlaw's Avatar
Made my own headers... needed a really tight fit and i was afraid the hookers would be more work then just making custom ones.. but others have been ok with the hookers with some tube work on the driver side....
Old 11-05-2005, 06:56 PM
Thunder175's Avatar
Just out of curiosity as well... did you go with a BMR K-member that was already setup for a BBC? And if so, what pan did you use? I'm trying to mock up a BBC, but I need to know what pan will fit.
Old 11-07-2005, 11:32 AM
Outlaw's Avatar
I used an AJE front end.. I have a dry sump pan but atleast with the AJE you can run any pan and I dont see a problem or how it would interfear
Old 11-07-2005, 12:16 PM
Thunder175's Avatar
Never even seen that one before. Do you feel that piece has any benefit (mostly for clearance) than the BMR K-member?
Old 11-07-2005, 12:46 PM
Outlaw's Avatar
I have no idea, I have never had a BMR one. All I can say is the AJE works great and fit like a charm
Quick Reply: 572 Big Block! ! !
